How to modle aerial atom chasiss?
hello,While i designing i cant able to design a particular rod in solidworks. i have attached a image in which the rod i cant design is marked with black lines. so please kindly send me details about how to draw that rod .please give tutorial. to aaaravindsekar@gmail.com
you go on side view you draw the curve following curvature of rod. make new sketch go on top view follow the curvature from the top. Project both curves on each other you get 3d curve make plane at the end draw circle sweep you have your rod
