How to move drawing to (0,0,0) cordinate ?
I want to import the attached file to cypecad for structural analysis. It mandatary that lower left corner of drawing should be moved at (0,0,0). How to do that?
If 0,0,0 isn't working try #0,0,0
With dynamic ucs turned on 0,0,0 can be set to "last point selected" and the move does nothing. Putting a # in front will force the command to always use absolute 0,0,0.
1 Command: Move <Enter
2 Select objects: all <Enter
3 (nr.) found
... Select objects:
4 Specify base point or [Displacement] <Displacement>: Click the base point on your DWG where you like to be at the origo. <Enter
5 Specify second point or <use first point as displacement>: 0,0,0 <Enter
You are done!
