How to move gear horizontally in the shaft and then rotate the gear by rotating the shaft in solidworks13?
By Mahmud Khan on 28 Jun 09:57 2 answers 11 comments
If i join the gear with the shaft by mating pitch circle , then i can't move the gear horizontally along the shaft. But when i mate the circular plane of the shaft and circular plane inside the gear , i can move the gear horizontally along the shaft but the gear doesn't rotate properly with the shaft
  • Inspire
    Inspire over 2 years ago
    I can show you example, but you must read HELP before asking so simple questions!
    BTW, I work in SW2015, so the following images will help you.
    This video show you what we'll have https://youtu.be/kEXS4TJeSi8
    Answered with a tutorial: https://grabcad.com/tutorials/how-to-move-gear-horizontally-in-the-shaft-and-then-rotate-the-gear-by-rotating-the-shaft-in-solidworks13
Add your answer to: "How to move gear horizontally in the shaft and then rotate the gear by rotating the shaft in solidworks13?"
