How to open an airfoil in ANSYS with using Solidworks?
See the model you have made in solidwoks of the airfoil, you can import it in the ansys workbench directly.
When you drag the type of solver, say FLUENT by left clicking on it and keeping it pressed and dropping it into the main window. On the geometry tab just below "Fluid Flow" just right click on it and click "import geometry". Select the corresponding file.
Hope this helps
