How to print a part in 4 views without seeing the dimesions in unnecessary angles
I'm having trouble viewing some of my work in SolidWorks. Ex. If a part is fully dimension from the front view, the overlapping numbers and dimension lines can be seen from the top as well. How can choose when to see the dimensions and when not to?
Comments 4
Can you post up a screen shot? I'd like to see exactly what youre seeing.
Attached is the only thing i could think of that changed what you are seeing. Make sure the flat to screen option isn't checked.
Options>system options tab>display/selection
