How to properly create a lofted boss/base in Solidworks
I am creating the hull of a sailboat. I have created a 2-d sketch on a series of planes parallel to the front plane at evenly spaced distances. When I try to create a lofted extrusion from the stern to the center of the boat it is created but looks funny. It appears to have squiggly lines even though the geometry looks correct. This model needs to be exact because it will be submitted to a 3-d printer. Any advice on what went wrong and how to fix it? Please see the attached photos. Thanks in advance!
It seams that you should use guide lines, search for a loft tutorial on youtube to learn how to use the guide lines.
Lofts are in general a tricky beast.
