How to put parametric dual dimension in hole table?
I have created a hole table in Creo Parametric 3 drawing by standard hole table function.All other dimensions in drawing I am showing as dual dimension "inch [mm]"
by proper config.,but the dimension in automatically generated hole table is only primary i.e. inch! How to show dual dimension in hole table?
Please refer the attached snapshot.
