How to quick change between named views? (keyboard shortcut)
Is there a shortcut for f.e. right view and for front view? Because in Customize>Commands>Views>*right>Show Properties I have disabled Accelerator option for assigning shortcut. (I can assign key only for "Named views..." window)
And second question: can I turn off the animation between switching views?
I will start with second question. You can turn off the animation in:
Tools/Options/General/Dysplay/Navigation/Animation during viewpoint modification.
To make a shortcut this is the tip. In customize/ Commands, search for the command of view "bottom" drag it to any toolbar in screen and the acellerator wont be grayed anymore, you can make this with all the views
