How to remove R symbol in Drafting while giving dimension to fillets
I want a default setting to remove R symbol in fillet dimension in Drafting for example lets say the fillet radius is R10 i want to remove that R in R10 by setting in Tools<Options<Mechanical Design<Drafting
And i dont want to try using properties settings.
Here is the solution. But you need to run catia as admin. and change your xml file. which one you are using. i show it with ISO. if you need how to run catia as admin. check below.
https://grabcad.com/questions/how-can-create-admin-mode-of-catia
Answered with a tutorial: https://grabcad.com/tutorials/how-to-remove-r-symbol-in-drafting-while-giving-dimension-to-fillets
use text with ladder
ı am actually more curious about why u need to delete R :)
