How to repair Autocad drawing from PDF convert?
I have problem to repair Autocad drawing that come from PDF after convert it. The line and dimension are totally out. How do I resolve this problem. Currently the original Autocad file are missing from our server. The last hope is the PDF drawing. Please some one advice any solution, software or trick that can use.
if the is missing or being erase from your server you can recover by using this software, EaseUS Data Recovery Wizard Professional
