How to repair imported geometry has 1 check entity error in Solidwork?
I want to use the assembly of human spine model in Solidwork, but i found the problem (imported geometry has 1 check entity error). So I can't use the model for finite element analysis in ANSYS Workbench. I hope in this community can help me to find the solutions of my problem.
Ok. Thanks.
It looks like from your picture that more than one part has a problem. Try opening each part of the assembly and run import diagnostics. It may be able to fix the errors. Not knowing how ANSYS works, you may also need to run feature recognition to populate the feature tree.
