How to restore corruped cdr files?
How to restore corruped cdr files? I want to restore my file cdr, there is a solution for a file with an error?
I'm looking for a solution for hours but found nothing. I have a deadline to meet for 3 days and would be grateful for any advice
Comments 2
But do you have an auto-backup configured? It is located at Tools->options -> (workspace) -> Save. You can set the elapsed time between backups (eg 10 minutes) as well as the destination folder. If you actually have it set you could look in the destination folder and see if there is a backup there. If not, consider setting it up for future use. You can also set it to make a backup upon saving the file.
There is something corrupted with the file as it has been saved that Corel won’t open it. Maybe there is a chance that another software that can import CorelDraw files might overlook the glitch and try to import the rest. Depends on what part of the file is corrupted.
See it here: http://www.techrepublic.com/forums/questions/i-want-to-restore-a-file-cdr-after-an-error/
If instrument above didn’t help, you would need to identify what may have caused the file corruption. Possible causes could include: • Document was corrupted / not saved due to the program crashing or hanging • Saving large files to a network drive.
An efficient CorelDraw (*.cdr) file recovery tool based on an intelligent data extraction algorithm and offering high speed of recovery and outstanding ease of use. Requires a copy of CorelDraw to operate.
http://www.purchase-software.org/data-recovery/cdr.html
