how to restore default color as gray for catia v5 R20
i was using catia v5 r16. recently i installed catia v5 r20. but after that whenever i make a part the default color is black nd is very transparent.
plz tell me how to restore the default color for parts
The releases are alway installed seperatly, different like most other software, you can use both with no relation between both installations.
Maybe R20 isn´t installed correct?
Helpfull (but a "hard" solution) is to delete the CATENV
C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\DassaultSystemes\CATEnv
CATIA will automatic install the standard CATENV.
Best regards
BTW: A "Dassault person" told me in the past to install always the odd number releases like R11, R13, R15, .. so better switch to R21
