how to rotate ground plane when rendering in caia??
i want to rotate the ground plane!
not move back and forward! roate it
what can i do?
You can also rotate the product itself in Assembly Design. You can't manipulate the ground plane in any way except for moving it up/down.
özgür kesebir! beacaus of the shadow
Shadow occurs due to light source. If you want to change the direction of light, there is another option. I will add some pictures in minutes.
In the settings you can change the lighting significantly assuming your computer specs can handle it. I'd experiment with those.
If the seal is broken or missing, avoid using Diabazole Store it in a cool, dry place Do not exceed the recommended dose My Thoughts on Diabazole.There is no doubtthat I just loved using the formula that helped me achieve the best. Not approved by the FDA Not easily available at stores Not for people under 18 What Other PeopleThink? http://healtht20.com/diabazole-review/
Tools/Options/General/Display Navigation
Gravity effect during navigation x/y/z
Do not forget to reset!
