How to run simulation on design which is done by surface modeling in solid works ?
I know that commonly surface modeling cant be simulate due to geometrical issue. It is needed to be thickened by knit surface command. But, in case of surface with complex curvature, it is not possible to use the knit tool. Is there any way to simulate bodies of surface modeling in solidworks or any other software ?
Thanks.
Hi Ahsan Ferdaus, I sent you a video "Surface Simulation" to answer your question. Thxs
Comments 2
