How to set inlet conditions for Venturi gas mixer?
I would like to simulate suction of air due to flow of air through nozzle and venturi tube (inlet conditions given on picture attached). I just cant get that effect.
Open Solidworks FloXpress. Before tht you will have to seal the inlet and outlet of ur model. Now for giving inlet conditions, Specify Smallest Flow passage (venturi) then give mass flow rate/volume flow rate (choose any one), then give pressure value and click solve.
