How to set one time Customer Defaults setting .
Hi all,
I have working on NX8 so i am facing the probleam annotaion setting and backgroud colour setting it is not set one time it is any new sesson is open then setting is chage so please tell me how to set one time Customer Defaults setting . i have try Customer Defaults setting change still probleam is not solve.
Thanking you!
Many of the annotation settings are saved in the part template file and over ride your default NX settings. To prevent this, open your default template part file, in Drafting go to Preferences>Annotations and select "Load All Defaults", then save the template file. Afterwards, your defaults should load when starting a new file. Use the same process to fix existing files.
