How to show fluid system inside a pipe and gate valve..?
Which is best to show water flow PF Source or super spray?
Want to show Pressure , Velocity , Density , viscosity , force and time then I think you can create Chart or add properties to that fluid . You can add velocity,density and viscosity of fluid in properties .
http://professorklein.com/production/animation_2009/3_D/Maya/Projects/Step_By_Step/Source_0/Tutorials_and_Extras/pdf/UsingMaya/Dynamics_and_Effects/FluidEffects.pdf
