how to use 2 shortcuts on one key
I want to have 2 shortcut commands on one key. in sketch mode, i use the C key for circle, and in assembly i use the C key for constrain. I have both commands to the C key, but when i'm in assembly and press C, i have to chose if i want circle or constrain. Is there a way i don't have to chose but still use both commands on the C key? It was possible in early inventor.
thanks,
Tijl
