How to use a part sketch as an assembly refference in Catia?
I want to make coincidence constraint with center of gear and and point on 1.png in attachment. However in assembly mode the point disappears. How can i do that?
second image is true one. you must use point as non construction element.
Insert also a point into the gear center in gear part file. Then use coincidence command in assembly mode.
