How to use helical sweep cut to make threads in Pro-E\Creo ??
By Saurabh Kumar on 13 Jun 12:28 7 answers 2 comments
Its easy to use helical sweep to cut threads in proe or creo elements...
I've selected a normal bolt...you can find a variety of them in library....
  • Vimal Tiwari
    Vimal Tiwari over 4 years ago
    I am having problem in defining sweep profile in step 6 above. Nothing is happening in pro e wildfire.
  • Arian Shamil
    Arian Shamil almost 4 years ago
    In creo 2.0 the procedure is slighty different (justs because menu are different) but anyway this tutorial helped me a lot! :)
    Great work and thanks to share this tutorial with us!
    THANKS!
  • Akshay Narayankar
    Akshay Narayankar almost 2 years ago
    Other than creating Springs ( both constant pitch and variable pitch) and Threading, what are the other application of Helical Sweep?
  • Nishi Panchal
    Nishi Panchal over 1 year ago
    Please let me know the steps to create internal threads in Creo 3.0 Parametric.
Add your answer to: "How to use helical sweep cut to make threads in Pro-E\Creo ??"
