How to write a text on curved surface, solidworks 2012
How to write a text (Coffee) on curved surface?
On this cup?
Hello dears,
At first you take the mid plan. And type your text on that plane. And then you extrude the text. And you need to extrude the boss as like From: from surface.
Wrap tool sometimes doesn't work. I suggest you to use extrude boss command. Offset from the surface always works. Just place the plane properly that you will use for it
haw make easy this blody stupid ,,plane'' ?
If it's a curve in a sketch draw the curve and then make it a "construction line" then select the text tool and select the curve and it will follow it.
