HOW we can make hole thorough all component in assemble with concentric constraint together?
some times we need make hole in assemble thorough the all component with concentric constraint .but i have problem with this because i cant make such holes in assemble envirnemet so i must make it one by one in the part !!!
Hi Saeid,
I found this application as an add-on from Autodesk Exchange Apps for Inv. 2013-14
It does exactly what you're willing to do...In the beginning you will like it and I believe you will agree that this is the solution for your problem ...well partially you will be right! BUT only partially!
I have to admit that is a smart tool but... I think it has some disadvantages...
Let me show you...
Answered with a tutorial: https://grabcad.com/tutorials/how-we-can-make-hole-thorough-all-component-in-assemble-with-concentric-constraint-together
HOW I can appreciate you.very thanks,but please if you can answer another of
my problem.
