how where how Unfold plate ..?
I had the IGES file, will I Unfold in SolidWorks. does anyone know how ..?
Actually, not impossible. Open up the actual part, not the assembly. Got to insert>sheet metal>convert to sheet metal. Then just select the inside area of the plate as your flat pattern plane. Then select collect bends. Then okay. It will automatically generate your flat pattern and everything.
it's impossible you must re make the model in sheet metal feature
