I am getting thiss error when i try to iopen a solidworks file....any help ??????????
Which edition (year) of solidworks do you have? It is very likely that the files you are trying to open are of a newer version than the version you are using. I've had the same issue in Inventor before. The easiest solution is to see if you can get them in a step. file format which is very universal to most softwares.
