I am unable to do simulation of a mechanism using "Assembly conversion" tools in DMU kinematics,Catia V5. I have uploaded the Assembly model. Can someone make it simulate??
I have made a simple linkage mechanism. I have uploaded the assembly file. The simulation result should come the same as using the manipulation parameter with respect to constraints and using drag along XZ plane. You can try that in assembly. But in DMU kinematics, after conversion of constraints into joints, fixing the part, adding commands, I am not able to simulate it at all. There is something wrong while placing the commands. Please someone work on it and simulate it asap!!!!
you must upload all parts too and not only the product, and I will try to help
Well thanks fr the reply. I actually did it finally and I have uploaded too!!
