I designed a porous flat plate and saved it in .stp format. But the .stp format when opened has the pocket reduced to half. I could not figure it out.
its about problem in .stp format.
Hoi Rajan ,
I did open the stp files, and the holes are just until the middle of the object.
Maybe it is a good idee to attach the file,
then I can find out what went wrong.
I assume that you have tried several times to convert your original file to a stp,
and that this has always gone wrong.
Greetings,
Danny
Are you trying to do this or something else?
Check It Out_
