i have a problem with 3d skech in solidwrks who can help?
i can't do vertical and horizontal smart quotation how can i do it
in a 3D sketch for that there are the axes (X, Y, Z) and other construction references of the model that you already have in progress, also remember that you can create plans in a 3d sketch temporarily generating a 2d space in which you can apply the mates standard of a 2D sketch if you have doubts or are not familiar with the sketch 3d check these tutorials, they can serve you
DESIGN A DODECAHEDRON IN SOLIDWORKS (Math Applied To Design)
DESIGN A ICOSAHEDRON IN SOLIDWORKS
3D sketch only supports sketching and wire frames. you can change direction of line by Tab key. it changes in X,Y and coordinate systems.. every time you have to use Tab to change axis
