I'm confused to choosing softwere between solid works and NX 10 which is more useful?
If you are looking for PLM software/ Complex surfacing go for NX, If your use is limited to design, Drafting and assembly Solidworks is best.
This is a professional comparison...
Check it out:
https://www.g2crowd.com/compare/design-to-siemens-nx-vs-solidworks
Really depends on the work you're doing.
If these were my preferences...
Collaborative, large assembly projects?
Top-down assembly?
One package for CAD/CAM/CAE?
The need for Sub-d modeling (Realize Shape module) within a parametric environment?
Synchronous modeling?
Surface models to Class-A modeling tolerances? (If you're looking to primarily model to Class-A, neither option would be my first choice)
NX
For everything else?
SWorks
