I'm Desperate! NEED A CONVERSION
I don't own SolidWorks and I received a .eprt file that I can't convert to either a .sldprt or a .obj file format HELP
Your best possibility was if the person making the eprt file saved it with the option allowing the file to be exported as an STL. Without that, the file can't saved/exported.
You could reverse engineer the design with section views, and the measuring tools, but it would take several hours.
Really appreciate the info. I'll get them to either re-save or get the right version
