I need help in single cad design
hey im a freshman student doing a small project , i have a drawing i made with illustrator , can anyone copy the same dimensions and make it in a cad file so i can laser cut it on sheet stainless steel ,
ps: please put each one into a single file
thanks alot
Here is a sample piece. Maybe make sure it will work for the intended task and make sure the arc radius values meet the application requirements.
The SolidWorks file is 2016 if anyone else wishes to use it.
hello dear i have converted all 3 models in seperate files hope it will work.
thank you soo much professors you made it alot easier for me.
thanks alot :)
