I Need Help With My ProjectAssembly.
Hello,
I am designing an assembly for a senior degree project. Its a subway floodgate system that can be used to prevent floodwater from going through the ventilation shafts. The doors are to be controlled using actuators. However, whenever I try contraining the holes of the actuator's clevis mount or the hole of the door hinges, I get error messages that the contraints are inconsisent or over-contrained. Am I doing something wrong? Attached is a zip folder containing the CATIA files for the project. The file 'MCD_Automated_Doors.CATProduct is the main assembly file.
I hope you must have either fixed hinges or the other part you made coincidence. Please check the constrains. Any how I will try to resolve your query
