I need to convert a STL model into a solid for use in AUTOCAD, I have 3DS and Revit as well if it helps
I am trying to build a big rendering in AutoCAD ACA and need to use some STL models. I just need them as low size solids files and not as 3D printer files with 150K polygons.
i think AUTOCAD can be opened if you give an extension .DWG
Hi,
Thank you I will have to try that one,
