I want to create a roof as shown in the sketch using Revit 2012
I want to create a roof using the method of "ROOF BY EXTRUTION" as shown in the sketch using Revit 2012. Free Hand drawing is provided. Pls upload the tutorial.
I would create the roof using the "Roof by Extrusion" tool. I would draw the profile that you want in the front elevation view then extrude it the depth needed. After that I would then switch to a side elevation view and create a void form the cut it form the roof, cutting of the roof at the angle needed. You may have to set up a reference plan to get the correct results for the angle. I have attached a image showing the out come form the steps above.
