In catia surface modelling how to give cuts or remove materials?
For example in designing a bottle how to give cuts in surface modelling
Comments 2
Here is the image of the bottle created in surface modelling
Okay. You can remove material using split and trim command. Split simply cuts the material and trim is the combination of trim and join. If you want to trim, join and give fillet to material, use shape fillet command.
