Is fillet possible between two non coplanar curves ?
I am working on fillet between two non coplanar curve ? But i am doubt fillet create a arc between two curve on same plane.
If you can use something like Tangent Tangent Radius then it's possible to some extent.
Actually if we draw two arc or line on same plane it will work but when planes are not coplanar and drawn entities are not connected to each other then it will not create fillet and reflect message planes are not coplanar.But if planes are not coplanar and both fillet entity share common point of contact then it will create arc by fillet option.
