Is is possible to draw heat shrink tubing?
I have a PCB with components and this is then wrapped with heat shrink tubing. Is it possible to make a drawing of this with SW?
See images - the first one is real life - the second is a rough drawing in SW without the "heat shrink feature".
Any inputs are much appreciated.
you would have to do a series of cross section profiles, then use surface loft and then thicken the resulting surface to required thickness.
You can cover the model with an extruded surface, then use the freeform tool to make the surface look like what you want by pulling here and there.
See this video.
https://www.youtube.com/watch?v=fuOtGyuuKnQ
