Is it possible to create a decal on 3 of the four sides of a rectangle surface in SolidWorks
I want to create a decal or engraved sketch that wraps around 3 sides of a rectangle.
I know you can do this on a flat or curved surface, but I need to wrap around to 3 of the four sides of a rectangle.
Do this by using the split line function....make a sketch..splitline the 3 surfaces, select these surfaces (hit ctrl) and the decal will spread over the selected area's....easy peazy....just try it!!
