Is it possible to move the Cg of an assembly to the origin of the assembly?
I am making an assembly to put into cd-adapco's STAR-CCM for CFD analysis. I need to put the Center of gravity of the entire assembly on the origin of the assembly file in order to easily set up the CFD simulation. Is this possible? I was thinking of trying to create a point in the assembly at the location of the center of gravity with respsect to the assembly file origin found using mass properties and then mating the origin and the created point. Is there a better option?
