Is it possible to turn a SLDASM into a SLDPRT?
I downloaded a part and I dont belive that it is a part because it is very complex. Is it possible uploader turned assemly into part?
File menu, save as, change type to *.sldprt
Yes, the Solidworks supports multi-body parts, which means part files can contain entire assemblies if that were their intent.
Sometimes I use that simplest option to save an assembly as a part file to prevent it from being misused or from getting rebuild errors on certain parts within assembly, the result is a solid body that will not blow up and will not make trouble and is usable as it is within other, larger assemblies, for example, a bicycle wheel :) Assemblies can also be saved as jpg files, 3D pdf and other formats...
Comments 2
2012 lets you explode mulit-body parts as well, just like an assembly!
