Is there a way to include a timing belt and pulleys for motion study in SolidWorks assemblies?
I am working on an assembly design in SolidWorks in which a timing belt with pulleys will be used. The belt will be used for as a means of linear motion for a bracket attached to the belt (the picture here is one i found online of a pulley system similar to what is desired). Motion studies will need to be preformed on this assembly. I know that there is a belt option in SW but will that tool work for this purpose?
Simply put:
-Can the belt option in SW be used for timing belts so i can mesh the track of belt with pulleys?
-Will adding holes to such a belt for mounting the bracket to the belt be problematic? If so, other methods to use so belt will cause linear travel?
