IS THERE ANY MAJOR DIFFERENCE IN ANSYS 12 AS COMPARED TO ANSYS 11....FOR MECHANICAL FIELD
I WANT TO KNOW WHAT CHANGES ARE THERE IN ANSYS 11,12,13,14......WITH RESPECT TO EACH OTHER FOR A MECHANICAL FIELD
Good morning,
Yes, the most higher differences appear to interface and most important to easiest manner in which can be done now (unfortunately for you I will extend your question for new version ANSYS 14.5) an simplification (using DesignModeller) and simulation. Basically, begin with ANSYS 12, the company start a revolution with this software, because I start to use it begin with version 8 and present (last version). Basically, the most differences appear to programing skills which every version is used less (especially for workbench where is working hard).
So, for supplementary informations I am to your disposition.
Best regards, and good look to try the latest version of ANSYS.
ahhhh stop yelling
