Is there any tool to check the wall thickness of irregular Body in Solid edge ???
I want to check the wall thickness of the irregular Body ,i am using solid edge ST7
I'm sorry I can't answer your question, but I may have a work around for you, I often use a cut extrude to cut a model and then put sketches on the cut surface to determine wall thickness of odd shapes. Hope this helps.
