Is there any way to label an assembly in solidworks?
I want to make identification of different parts of a SolidWorks assembly. Looking for a way to label different parts with different names. A picture is attached for better understanding.
Not sure I understand completely but it looks like you are trying to label different dimensions so that you can plug them into a table later and generate parts of multiple sizes or dimensions.
Once you establish a dimension click inside the top portion and it will allow you to rename the dimension line. In the picture it was D1 so the description is D1@sketch1.
You can change the name or set them to equations if needed.
