Is there any way to mix a gas with a liquid in NX (8.5)?
Hello,
I'm currently trying to solve a problem related with the simulation of the cardiovascular system. In particular, parametric computational simulations involving different fluid (blood, in our case) and gas flow rates.
I saw that there is a 'modeling object' in NX 8.5 which enables to mimic mass transport (flow + particles).
Firstly, I tried to create a 'homogeneous gas mixture' and it worked.
Now I would like to extend my analysis to interactions between gas/liquid by means of the 'modeling object' called as 'heterogeneous gas-liquid mixture'.
Ideally I would to simulate blood (as a liquid) + oxygen dissolved (as a gas).
I tried several times to run this 'modelling object' in my CFD simulation but every time I get a 'fatal error' back.
Is anyone familiar with this kind of 'modeling object'?
Thanks in advance for your help
Daniele
beef.
hope this answer was helpful to you
contact me if you have any questions
