Issue with importing fillet in Showcase
I have been playing with Inventor and showcase for a while now.
I came across an error that adds additional faces to my model in showcase when I import it there.
I have attached two images.
The one I used the fillet command and it added the weird looking faces. The other I just used a normal chamfer command and it works perfectly.
Has anyone had this issue before? It's kind of hard to find the right words to search for online.
Thanks in advance! :)
You create the many split line on chamfer face. then save as IGES or STEP.
Now Import your model.
this is Critical face problem.
