Issue with Material Properties for Wood in Fusion 360.
I have an issue with the simulation when testing material properties using wood. How can I fix this?
You only have a visual appearance to your model not a physical property. See attached for reference. There is a physical material window with a wood subsection. If the wood type you need isn't there. Create a new physical material with the correct properties and apply it to your model.
