Just can't get it right (tangent relations) making a simplified 2 storke engine.
so, i'm trying to create this for my assignemt, but the first part I can not get around to...
this is what I'm stuck on:
https://puu.sh/yACBf.png
my problem is I do not know how to add the tangent relation, and im pretty sure that it is the reason I can't get the last step in the correct position.
Can someone explain this to me? thank you
I am not sure what steps you followed. So I cannot tell you where you went wrong or you are stuck. I made the part, a very rough version, check if this is what you need to do. Hope this helps.
Click the circle sketch, shift+click the side of the rectangle, click 'Tangent' relation, click the check-mark.
Not a direct answer but here is a (lengthier) video describing many of the relations available and then a brief showing of how it could be used.
https://www.youtube.com/watch?v=KamVYNKhOlE
Some are pretty basic, but it could provide some help in the future.
Also the real SW link with their descriptions and breakdowns:
http://help.solidworks.com/2016/english/solidworks/sldworks/hidd_dve_sketch_default.htm
