modelling a set of holes with different diameters on a plate from excel coordinates
I have several plates each one with a bunch of holes with different diameters and I want to know how to draw then all in a single task using a excel file with coordinates like
x,y,z,radius.
Thank You in advance
What you want to do is accomplished with a design table. You can insert an external excel file as a 'design table' into your parts and link model dimensions to the values listed in the table.
Can you post screenshots of the files? Alot of times, the coordinates are referenced from the bottom left corner of the plate, and then the points are placed at the x,y dimensions given.
You should also be able to use pattern table to accomplish that.
http://help.solidworks.com/2016/english/solidworks/sldworks/c_pattern_tables.htm
