modify a component to have a different bend angle only in a certain assembly
i have a piece of flat bar that is a component. i need to modify the bar in one specific assembly to have a bend in it but not change the actual component any where else. i have done this in UG using moments. how can i do this in Solid Edge
I know solidworks has a 'Configuration' menu that allows changing a part for a specific state only. You are able to change the part in each configuration independently or as a grouping.
Here is a link that talks about Solid Edge and its equivalent of a SW Configuration.
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Does-Solid-Edge-do-anything-like-SolidWorks-configurations/td-p/1436
